20 years agoUCLinux build errors with DE2 Board 2C35.
I installed the Nios II Linux v1.4 released. System : XP, quartus v51, nios v51. Board : DE2 with 2C35. I do exactly what is say in the microtronix “Quick Start Quide.pdf” but I’ve got some errors when i build my linux kernel./cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c: In function `init_hwif_default':
/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:262: error: `na_ide_ide' undeclared (first use in this function)
/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:262: error: (Each undeclared identifier is reported only once
/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:262: error: for each function it appears in.)
/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c: In function `init_ide_data':
/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:313: error: `na_ide_ide_irq' undeclared (first use in this function)
make: *** Error 1
make: *** Error 2
make: *** Error 2
make: *** Error 2
make: Leaving directory `/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' Does Nios II Linux v1.4 support DE2_Board ? I think that my kernel configuration is good. Maybe one problem with the *.ptf but i don’t know exactly. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif Could u help me, Thanks!12 Replies
In fact, for the moment i don't need the network fonctions. So I've disable all in my config. Then I've build my kernel perfectly.
I've download it in RAM and when i launch the terminal it says this log: nios2-terminal: log (http://c.beyls.free.fr/log-error.jpg) http://c.beyls.free.fr/log-error.JPG What do u think about it ? For the moment, I'haven't load my filesystem. Do u think that my kernel is ok ? - Altera_Forum
--- Quote Start --- originally posted by pairin20@May 15 2006, 05:19 AM in fact, for the moment i don't need the network fonctions. so i've disable all in my config. then i've build my kernel perfectly.i've download it in ram and when i launch the terminal it says this log:
what do u think about it ?
for the moment, i'haven't load my filesystem. do u think that my kernel is ok ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15362)
--- quote end ---
--- Quote End --- You must have root file system to run Linux. If you want to use romfs on CFI for rootfs , you must modify the altera.c map file for mtd. Last advice, follow buildroot guide. There is a kernel image which you can try without compiling anything.
