20 years agoUCLinux build errors with DE2 Board 2C35.
Hi, I installed the Nios II Linux v1.4 released. System : XP, quartus v51, nios v51. Board : DE2 with 2C35. I do exactly what is say in the microtronix “Quick Start Quide.pdf” but I’ve...
20 years ago --- Quote Start --- originally posted by pairin20@May 15 2006, 05:19 AM in fact, for the moment i don't need the network fonctions. so i've disable all in my config. then i've build my kernel perfectly.
i've download it in ram and when i launch the terminal it says this log:
nios2-terminal: log (http://c.beyls.free.fr/log-error.jpg)
what do u think about it ?
for the moment, i'haven't load my filesystem. do u think that my kernel is ok ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15362)
--- quote end ---
--- Quote End --- You must have root file system to run Linux. If you want to use romfs on CFI for rootfs , you must modify the altera.c map file for mtd. Last advice, follow buildroot guide. There is a kernel image which you can try without compiling anything.
