13 years agoUbuntu 13.04: Segmentation Fault during MegaWizard ALTDDIO_OUT creation
hardware: DE2-115 development board (Cyclone IV)
os: Ubuntu 13.04 64-bit I'm trying to follow the Triple Speed Ethernet tutorial (I can't include the link, but it's "using_triple_speed_ethernet.pdf" on the Altera tutorials page) which has been without issue up until I try to create the ALTDDIO_OUT. I've launched Quartus from the terminal; when I open the MegaWizard Plugin Manager and select ALTDDIO_OUT, name the file and then click "Next", a window pops open for a moment, begins to load but exits early (Segmentation Fault printed to the terminal), and then I am returned to [page 2a]. Somebody posted something similar having issues with ALTPLL ... MegaWizard worked just fine when I generated the PLL, so I'm at a loss for why this is different. Any help would be greatly appreciated!2 Replies
I'm having this same problem. I'm running Quartus II v13.0 on a remote server. I can launch and create an ALTCLKCTRL and successfully create the megafunction.
But I canNOT create the ALTDDIO_OUT. I get "Can't create the custom megafunction variation file(s)." error message along with an "Error in CNX file format". Can someone help? - Altera_Forum
--- Quote Start --- I'm having this same problem. I'm running Quartus II v13.0 on a remote server. I can launch and create an ALTCLKCTRL and successfully create the megafunction. But I canNOT create the ALTDDIO_OUT. I get "Can't create the custom megafunction variation file(s)." error message along with an "Error in CNX file format". Can someone help? --- Quote End --- here's the failure sequence:I open a terminal window, issue this command: shell xxx/13.0/linux32 Then issue: quartus & Quartus launches. I go to Tools -> MegaWizard -> Create new…. -> ALTDDIO_OUT -> enter name hit Next MegaWizard will not lauch. I get a couple of *cnx* files. My terminal window shows “Error: "Can't create the custom megafunction variation file(s)." error message along with an "Error in CNX file format". So I go into my desktop windows Quartus version, create the ALTDDIO_OUT function, copy the 4 verilog files (.qip, .v, _bb.v, inst.v) to my unix directory, instantiate the altddio_OUT in my Top Verilog design, hit compile, Quartus crashes/shuts down/core dump in terminal window. I’ve switched to “shell xxx/13.0/linux64, MegaWizard will now launch and create ALTDDIO_OUT.
