13 years agoUart loopback
Hello guys, I have created a nios2 system with a uart port: uart_0 I have put the rx_uart and tx_uart in short circuit. So I expect that what I send is what I get. Finally I have writ...
13 years ago --- Quote Start --- Thank you for your reply !! I have tried with a multimeter and I put the write comman in a loop. What I see is that the pin is always at 0 V. There is an instruction that put a specified pin (eg pin_d22) on high state so that i can test if the pin i have assigned to the txd_uart is the pin I really use in hardware ? It could be harmful ? Alternatively what about if I set the output pin (tx_uart) as the clock pin ? Thank you !! Have a nice day. --- Quote End --- I have put the input clock on the output pin assigned to the txd_uart but still cannot see anything.. mumble mumble.. any suggestion ??
