13 years ago
U-Boot to boot without any tty console [Nios II MMU]
I have a 3c120 board running linux with the help of http://www.rocketboards.org/foswiki/documentation/niosiilinuxusermanual#how_to_debug_kernel_47drivers_with_gdb
But what I see is that U-Boot does not boot until I connect via nios2-terminal, I can see there are several configurations and env I can set in U-Boot. But not clear what variable I can set / modify to boot U-Boot without any user interaction.
U-Boot config looks like this
/* added environment to ease user usage */
#define config_auto_complete
#define config_bootargs "console=ttyj0,115200"
#define config_extra_env_settings \
"fdtaddr=0xd5000000\0" \
"loadaddr=0xd6000000\0" \
"fdtimagesize=0x1000\0" \
"bootimagesize=0x200000\0" \
"cfifdtaddr=0xe0200000\0" \
"cfibootaddr=0xe0300000\0" \
"cfiroot=/dev/mtdblock0 rootfstype=jffs2 rw\0" \
"cfiload=cp.b ${cfifdtaddr} ${fdtaddr} ${fdtimagesize};" \
"cp.b ${cfibootaddr} ${loadaddr} ${bootimagesize}\0" \
"cfiboot=setenv bootargs " config_bootargs " root=${cfiroot};" \
"bootm ${loadaddr} - ${fdtaddr}\0" \
"nfsdhcpboot=setenv bootargs " config_bootargs " root=/dev/nfs " \
"rw nfsroot=${serverip}:${rootpath},tcp " \
"ip=dhcp;bootm ${loadaddr} - ${fdtaddr}\0" \
"nfsstaticboot=setenv bootargs " config_bootargs " root=/dev/nfs " \
"ip=${ipaddr}:${serverip}:${gatewayip}:${netmask};" \
"serverip=196.168.96.11\0" \
"rootpath=/home/nios2/nfs\0" \
"ipaddr=196.168.96.10\0" \
"gatewayip=196.168.96.254\0" \
"netmask=255.255.255.0\0" \
"ethaddr=22:33:44:55:66:77\0"
#define config_cmd_run
/* boot command will automatically executed */
#define config_bootcommand "run cfiload; run cfiboot"
/* delay before automatically booting the default image */
You can see there is boot arg defined as console=ttyj0,115200 .Is that where the magic happens why it waits for the nios2-terminal before it boots? Thanks!
    Hi
    --- Quote Start ---
    --- Quote End ---
    Please confirm it as follows once.
    make menuconfig
    Kernel/Library/Defaults Selection ---> [*] Customize Kernel Settings <Exit>
    Device Drivers ---> Character devices ---> Serial drivers --->
    [*] Bypass output when no connection
    .config - Linux Kernel v2.6.30 Configuration
    &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;
    &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472; Serial drivers &#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    &#9474; Arrow keys navigate the menu. <Enter> selects submenus --->. &#9474;
    &#9474; Highlighted letters are hotkeys. Pressing <Y> includes, <N> excludes, &#9474;
    &#9474; <M> modularizes features. Press <Esc><Esc> to exit, <?> for Help, </> &#9474;
    &#9474; for Search. Legend: [*] built-in [ ] excluded <M> module < > &#9474;
    &#9474; &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488; &#9474;
    &#9474; &#9474; < > 8250/16550 and compatible serial support &#9474; &#9474;
    &#9474; &#9474; *** Non-8250 serial port support *** &#9474; &#9474;
    &#9474; &#9474; < > MAX3100 support &#9474; &#9474;
    &#9474; &#9474; [*] Altera JTAG UART support &#9474; &#9474;
    &#9474; &#9474; [*] Altera JTAG UART console support &#9474; &#9474;
    &#9474; &#9474; [ ] Bypass output when no connection &#9474; &#9474;
    &#9474; &#9474; [*] Altera UART support &#9474; &#9474;
    &#9474; &#9474; (4) Maximum number of Altera UART ports &#9474; &#9474;
    &#9474; &#9474; (115200) Default baudrate for Altera UART ports &#9474; &#9474;
    &#9474; &#9474; [ ] Altera UART console support &#9474; &#9474;
    &#9474; &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496; &#9474;
    &#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
    &#9474; <Select> < Exit > < Help > &#9474;
    &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    Did you select it?
    Kazu
    Thanks kazuyasu!
    I assume all these configs are done in Linux kernel, right? I dont think there is any configs I could do in U-Boot. All I could do there was "make <boardname>_config" and make.
    And in kernel settings, I couldnt find
    Kernel/Library/Defaults Selection --->[*] Customize Kernel Settings <Exit>
    But I could modify the rest of the settings regarding the "Bypass output when no connection" for the serial connection.
