13 years agoU-Boot to boot without any tty console [Nios II MMU]
I have a 3c120 board running linux with the help of http://www.rocketboards.org/foswiki/documentation/niosiilinuxusermanual#how_to_debug_kernel_47drivers_with_gdb But what I see is that U-Boot doe...
13 years agoHi
--- Quote Start --- But what I see is that U-Boot does not boot until I connect via nios2-terminal, I can see there are several configurations and env I can set in U-Boot. --- Quote End --- Please confirm it as follows once. make menuconfig Kernel/Library/Defaults Selection ---> [*] Customize Kernel Settings <Exit> Device Drivers ---> Character devices ---> Serial drivers ---> [*] Bypass output when no connection .config - Linux Kernel v2.6.30 Configuration ────────────────────────────────────────────────────────────────────────────── ┌──────────────────────────── Serial drivers ─────────────────────────────┐ │ Arrow keys navigate the menu. <Enter> selects submenus --->. │ │ Highlighted letters are hotkeys. Pressing <Y> includes, <N> excludes, │ │ <M> modularizes features. Press <Esc><Esc> to exit, <?> for Help, </> │ │ for Search. Legend: [*] built-in [ ] excluded <M> module < > │ │ ┌─────────────────────────────────────────────────────────────────────┐ │ │ │ < > 8250/16550 and compatible serial support │ │ │ │ *** Non-8250 serial port support *** │ │ │ │ < > MAX3100 support │ │ │ │ [*] Altera JTAG UART support │ │ │ │ [*] Altera JTAG UART console support │ │ │ │ [ ] Bypass output when no connection │ │ │ │ [*] Altera UART support │ │ │ │ (4) Maximum number of Altera UART ports │ │ │ │ (115200) Default baudrate for Altera UART ports │ │ │ │ [ ] Altera UART console support │ │ │ └─────────────────────────────────────────────────────────────────────┘ │ ├─────────────────────────────────────────────────────────────────────────┤ │ <Select> < Exit > < Help > │ └─────────────────────────────────────────────────────────────────────────┘ Did you select it? Kazu
