15 years ago
Triple-Speed Ethernet with ksz8893
I want to use the mii of ksz8893 connect to Triple-Speed Ethernet ,but it cannot work.
my socket can listenning, but i cannot ping from pc.please tell me what should i do?
    --- Quote Start ---
    So you would only need to check the connection status of the other 2 PHYs, and return when one is connected.
    If you don't care whether a line is connected or not (as is possible for testing), just return any correct value for the link status
    --- Quote End ---
    Thanks my friend,
    you mean,I don't need to check the 3th mac(link to my mii)?
    I just check phy1 or phy2 link good?
    Hi my friends,
    This is my new report,
    --- Quote Start ---
    Please enter your 9-digit serial number. This is printed on a
    label under your Nios dev. board. The first 3 digits of the
    label are ASJ and the serial number follows this.
    -->Created "Inet main" task (Prio: 2)
    Created "clock tick" task (Prio: 3)
    123456789
    123456789
    Your Ethernet MAC address is ff:ff:ff:ff:38:55
    Static IP Address is 192.168.1.30
    prepped 1 interface, initializing...
    [tse_mac_init]
    INFO : TSE MAC 0 found at address 0x0a005000
    INFO : PHY KSZ8893 found at PHY address 0x01 of MAC Group[0]
    INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
    INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
    INFO : PHY[0.0] - Auto-Negotiation PASSED
    INFO : PHY[0.0] - Checking link...
    INFO : PHY[0.0] - Link established
    INFO : PHY[0.0] - Speed = 100, Duplex = Full
    OK, x=0, CMD_CONFIG=0x01000000
    MAC post-initialization: CMD_CONFIG=0x05000203
    [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
    mctest init called
    IP address of et1 : 192.168.1.30
    Simple Socket Server starting up
    [sss_task] Simple Socket Server listening on port 30
    Created "simple socket server" task (Prio: 4)
    --- Quote End ---
    I still cannot ping through from pc to my nios.
    I had check my ksz8893's mii by omap-L138, and it can work good.
    What should I do?
    Thank you very much !!
    Hi all my friends,
    Thanks for your help, my ksz8893 has been working well.
    Thanks again!
    --- Quote Start ---
    Hi all my friends,
    Thanks again!
    --- Quote End ---
    If available, please show the code for other persons, that may have such problems in the future.
    --- Quote Start ---
    --- Quote End ---
    I will post my code and project in the next few days, I am ordering them.
    I have meet the same problem,could you tell me how to fix it?
