15 years agoTriple-Speed Ethernet with ksz8893
I want to use the mii of ksz8893 connect to Triple-Speed Ethernet ,but it cannot work. my socket can listenning, but i cannot ping from pc.please tell me what should i do?
15 years ago --- Quote Start --- So you would only need to check the connection status of the other 2 PHYs, and return when one is connected. If you don't care whether a line is connected or not (as is possible for testing), just return any correct value for the link status --- Quote End --- Thanks my friend, you mean,I don't need to check the 3th mac(link to my mii)? I just check phy1 or phy2 link good?
