--- Quote Start --- So you would only need to check the connection status of the other 2 PHYs, and return when one is connected. If you don't care whether a line is connected or not (as is possible for testing), just return any correct value for the link status --- Quote End --- Thanks my friend, you mean,I don't need to check the 3th mac(link to my mii)? I just check phy1 or phy2 link good? - Altera_Forum
Hi my friends,
This is my new report, --- Quote Start --- Please enter your 9-digit serial number. This is printed on a label under your Nios dev. board. The first 3 digits of the label are ASJ and the serial number follows this. -->Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) 123456789 123456789 Your Ethernet MAC address is ff:ff:ff:ff:38:55 Static IP Address is 192.168.1.30 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x0a005000 INFO : PHY KSZ8893 found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x01000000 MAC post-initialization: CMD_CONFIG=0x05000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.30 Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) --- Quote End --- I still cannot ping through from pc to my nios. I had check my ksz8893's mii by omap-L138, and it can work good. What should I do? Thank you very much !! - Altera_Forum
Hi all my friends,
Thanks for your help, my ksz8893 has been working well. Thanks again! - Altera_Forum
--- Quote Start --- Hi all my friends, Thanks for your help, my ksz8893 has been working well. Thanks again! --- Quote End --- If available, please show the code for other persons, that may have such problems in the future. - Altera_Forum
--- Quote Start --- Originally Posted by Socrates If available, please show the code for other persons, that may have such problems in the future. --- Quote End --- I will post my code and project in the next few days, I am ordering them. - Altera_Forum
I have meet the same problem,could you tell me how to fix it?
