21 years agotouch file
I have a file that includes the standard __DATE__ and __TIME__ macros and other information, and prints it to the console. I use this as a quick way of checking the build version of my software. I need to force the file to be recompiled every build, since the code itself never changes and it is easy to forget to open and save the file during a busy debug session. The shell command "touch <file>" wouild do this if made part of the makefile.
Is there a convenient point - script file - in the IDE tool chain where I could insert this command? Or is there a way to include a user script at the start of every build? I want to keep using the IDE and so need to limit the rework whenever it is upgraded.2 Replies
There's lots of ways to do this. One possible way is to create a seperate makefile (e.g. touch.mk) which contains something like the following:
Then from the Windows control panel create the environment variable MAKEFILES which has as it's value the path to the makefile you just created, e.g. C:/touch.mk. Alternatively you could just add the above content to app.mk in the Nios II kit. I haven't tested the above, but something like it should work.all: touch_myfile touch_myfile: touch my_file.c .PHONEY: touch_myfile - Altera_Forum
Perfect! Thank you for the solution, it works really well. I used MAKEFILES to avoid modifying any NIOS files. This is the script that works for me:
[-c flag to prevent dumping spurious empty .c files as the make traverses directories; ../ as the make executes in the Release or Debug directory below the source file.] http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gifall: touch_myfile touch_myfile: touch -c ../mybuildinfo.c echo "Touch script running in: " `pwd` .PHONEY: touch_myfile
