21 years agotouch file
I have a file that includes the standard __DATE__ and __TIME__ macros and other information, and prints it to the console. I use this as a quick way of checking the build version of my software. I ...
21 years agoThere's lots of ways to do this. One possible way is to create a seperate makefile (e.g. touch.mk) which contains something like the following:
all: touch_myfile
touch_myfile:
touch my_file.c
.PHONEY: touch_myfile Then from the Windows control panel create the environment variable MAKEFILES which has as it's value the path to the makefile you just created, e.g. C:/touch.mk. Alternatively you could just add the above content to app.mk in the Nios II kit. I haven't tested the above, but something like it should work.
