13 years agoThere are no Nios II CPUs with debug modules available
Hi, I am facing this problem for over a week now, where when i try to debug as nios hardware the following error message shows up: There are no Nios II CPUs with debug modules available wh...
13 years agoHi, i got it work by using this command line:
nios2-download -g hello_world_1.elf && nios2-terminal /cygdrive/d/niostest/hello_world_1/hello_world_1/Debug [NiosII EDS]$ nios2-download -g hello_world_1.elf && nios2-terminal Using cable "USB-Blaster [USB-0]", device 1, instance 0x02 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 20KB in 0.3s (66.6KB/s) Verified OK Starting processor at address 0x000081C8 nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 2 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) hehehaha Nios II! But when i use Debug as (on the Nios2 9.0 IDE) it shows the same error: There are no Nios II CPUs with debug modules available which match the values specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary.
