20 years agoTHE WM8731 ON DE2
THE WM8731 ON DE2
serial data from digital audio interface I want to make "serial data", which is out of digital audio interface after AD sampling in WM8731,into the 16bit "parallel data",which will be stored in the SRAM on theED2 board. So I want to ask what should I do? Are there some module programme available? Some days ago, I have write a verilog programme for serial-to-parallel conversion.But, the result of function simulation is not correct. ps:1.AD sampling rate is 8KHZ 2.ADCDAT is 16 bit 3.NORMAL mode 4.digital audio interface format is I2S. 5.programme I have write as follow:2 Replies
//when AUD_ADCLRC==0, do 16bit serial-to-parallel.this module is only// //for leftchannel AUD_ADCDAT data. // /////////////////////////////////////////////////////////////////////// module leftchannel(clk,reset,AUD_ADCLRC_n,AUD_ADCDAT,pDATAOut,en); input clk; //connect BCLK, module time input reset; // input AUD_ADCLRC_n; input AUD_ADCDAT; //serial data from digital audio interface output[15:0] pDATAOut; //parallel output en; // enable output wire clk; wire reset; wire AUD_ADCLRC_n; wire AUD_ADCDAT; reg en; reg [15:0] pDATAOut; reg [15:0] pDATAOut_temp; reg [5:0] counter ; //counter for state S2 reg [8:0] counter0; //counter for state S3 reg [1:0] state; // parameter S0=2'b00, // S1=2'b01, // S2=2'b11, // S3=2'b10; // always @(negedge reset or negedge clk) begin if (!reset) begin state <= S0; // //counter <= 5'b00000; //counter0 <= 8'b0000_0000; end else begin case(state) // S0: begin if (AUD_ADCLRC_n == 1) state <= S0; // else state <= S1; end S1: begin state <= S2; end S2: begin if (counter == 5'b10000) state <= S3; else state <= S2; end S3: begin if (counter == 8'b1010_1111) state <= S0; else state <= S3; end endcase end end always @ (negedge clk) // (state) begin case(state) S0: begin pDATAOut_temp <= 4'h0000; en <= 1'b0; counter <= 5'b00000; counter0 <= 8'b0000_0000; end S1: begin pDATAOut_temp <= 4'h0000; en <= 1'b0; counter <= 5'b00000; counter0 <= 8'b0000_0000; end S2: begin en <= 1'b0; case(counter) 5'b00000: begin pDATAOut_temp[15] <= AUD_ADCDAT; counter <= counter+5'b00001; end 5'b00001: begin pDATAOut_temp[14] <= AUD_ADCDAT; counter <= counter+5'b00001; end . . . 5'b01111: begin pDATAOut_temp[0] <= AUD_ADCDAT; counter <= counter+5'b00001; end default: counter <= counter+5'b00001; endcase end S3: begin //if (counter0 == 8'b0000_0000) begin en <= 1'b1; pDATAOut <= pDATAOut_temp; counter0 <= counter0+8'b0000_0001; end //else //begin //en <= 1'b0; // pDATAOut_temp <= 4'h0000; // pDATAOut <= 4'h0000; //counter0 <= counter0+8'b0000_0001; //end end endcase end endmodule - Altera_Forum
THANKS FOR every engineers and friends
my e-mail : [email protected]
