20 years agoTHE WM8731 ON DE2
THE WM8731 ON DE2 serial data from digital audio interface I want to make "serial data", which is out of digital audio interface after AD sampling in WM8731,into the 16bit "parallel data",whi...
20 years ago///////////////////////////////////////////////////////////////////////
//when AUD_ADCLRC==0, do 16bit serial-to-parallel.this module is only// //for leftchannel AUD_ADCDAT data. // /////////////////////////////////////////////////////////////////////// module leftchannel(clk,reset,AUD_ADCLRC_n,AUD_ADCDAT,pDATAOut,en); input clk; //connect BCLK, module time input reset; // input AUD_ADCLRC_n; input AUD_ADCDAT; //serial data from digital audio interface output[15:0] pDATAOut; //parallel output en; // enable output wire clk; wire reset; wire AUD_ADCLRC_n; wire AUD_ADCDAT; reg en; reg [15:0] pDATAOut; reg [15:0] pDATAOut_temp; reg [5:0] counter ; //counter for state S2 reg [8:0] counter0; //counter for state S3 reg [1:0] state; // parameter S0=2'b00, // S1=2'b01, // S2=2'b11, // S3=2'b10; // always @(negedge reset or negedge clk) begin if (!reset) begin state <= S0; // //counter <= 5'b00000; //counter0 <= 8'b0000_0000; end else begin case(state) // S0: begin if (AUD_ADCLRC_n == 1) state <= S0; // else state <= S1; end S1: begin state <= S2; end S2: begin if (counter == 5'b10000) state <= S3; else state <= S2; end S3: begin if (counter == 8'b1010_1111) state <= S0; else state <= S3; end endcase end end always @ (negedge clk) // (state) begin case(state) S0: begin pDATAOut_temp <= 4'h0000; en <= 1'b0; counter <= 5'b00000; counter0 <= 8'b0000_0000; end S1: begin pDATAOut_temp <= 4'h0000; en <= 1'b0; counter <= 5'b00000; counter0 <= 8'b0000_0000; end S2: begin en <= 1'b0; case(counter) 5'b00000: begin pDATAOut_temp[15] <= AUD_ADCDAT; counter <= counter+5'b00001; end 5'b00001: begin pDATAOut_temp[14] <= AUD_ADCDAT; counter <= counter+5'b00001; end . . . 5'b01111: begin pDATAOut_temp[0] <= AUD_ADCDAT; counter <= counter+5'b00001; end default: counter <= counter+5'b00001; endcase end S3: begin //if (counter0 == 8'b0000_0000) begin en <= 1'b1; pDATAOut <= pDATAOut_temp; counter0 <= counter0+8'b0000_0001; end //else //begin //en <= 1'b0; // pDATAOut_temp <= 4'h0000; // pDATAOut <= 4'h0000; //counter0 <= counter0+8'b0000_0001; //end end endcase end endmodule
