20 years ago
The NIOS II doesn't reply.
everytime I want to connect to my NIOS II via the ByteBlaster cable (at my LPT port) the following messages appears in the NIOS II IDE
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
The FPGA is successfully programm with the NIOS II design and the FPGA works fine, if I program it with some "by-hand-made" designs.
What do I do wrong? The design in the SOPC Builder contains just the CPU a onchip memory and the JTAG UART; nothing more, and I can't persuade it to work. :-(
Can someone help me?
1 Reply
    Two things come to mind at the moment regardinging your problem.
    1) Debug Core: Make sure that you have added a debug core to your processor in SOPC Builder. This is done through the Nios II editor (double-click on the cpu in the table). If you don&#39;t have a debug core for the processor, then you&#39;re out of luck. I can&#39;t remember if the Nios II IDE will tell you this, however. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    2) Open Core Plus: If you are using an unlicense (evaluation) version of the Nios II core, make sure that you leave the open-core dilalog box running in Quartus. This message box will appear after you download the compiled SOF file to your board if it contains a Nios II processor. Don&#39;t click "cancel" on this message box if you intend to debug your system!!
    Hope one of these solutions helps. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
    --- Quote Start ---
    originally posted by grubenkarlo@Jul 3 2006, 08:57 AM
    hello,
    everytime i want to connect to my nios ii via the byteblaster cable (at my lpt port) the following messages appears in the nios ii ide
    using cable "byteblasterii [lpt1]", device 1, instance 0x00
    pausing target processor: not responding.
    resetting and trying again: failed
    leaving target processor paused
    the fpga is successfully programm with the nios ii design and the fpga works fine, if i program it with some "by-hand-made" designs.
    what do i do wrong? the design in the sopc builder contains just the cpu a onchip memory and the jtag uart; nothing more, and i can&#39;t persuade it to work. :-(
    can someone help me?
    thanks.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16630)
    --- quote end ---
    --- Quote End ---
