20 years agoThe NIOS II doesn't reply.
Hello, everytime I want to connect to my NIOS II via the ByteBlaster cable (at my LPT port) the following messages appears in the NIOS II IDE Using cable "ByteBlasterII [LPT1]", device 1, ...
20 years agoHello,
Two things come to mind at the moment regardinging your problem. 1) Debug Core: Make sure that you have added a debug core to your processor in SOPC Builder. This is done through the Nios II editor (double-click on the cpu in the table). If you don't have a debug core for the processor, then you're out of luck. I can't remember if the Nios II IDE will tell you this, however. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif 2) Open Core Plus: If you are using an unlicense (evaluation) version of the Nios II core, make sure that you leave the open-core dilalog box running in Quartus. This message box will appear after you download the compiled SOF file to your board if it contains a Nios II processor. Don't click "cancel" on this message box if you intend to debug your system!! Hope one of these solutions helps. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif --- Quote Start --- originally posted by grubenkarlo@Jul 3 2006, 08:57 AM hello,
everytime i want to connect to my nios ii via the byteblaster cable (at my lpt port) the following messages appears in the nios ii ide
using cable "byteblasterii [lpt1]", device 1, instance 0x00
pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused
the fpga is successfully programm with the nios ii design and the fpga works fine, if i program it with some "by-hand-made" designs.
what do i do wrong? the design in the sopc builder contains just the cpu a onchip memory and the jtag uart; nothing more, and i can't persuade it to work. :-(
can someone help me?
thanks.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16630)
--- quote end ---
--- Quote End ---
