Michael2021
1 year agoThe error message is as follows: "nios2-bsp-update-settings : command not found"
I downloaded the A10_DP_RX_FMC_PRO.par file and compiled it with Quartus Pro 19.2. AN 900: Intel® Arria 10 DisplayPort 8K RX-only Design Link: https://www.intel.com/content/www/us/en/docs/programma...
AdrianaI_Altera
1 year agoHi @Michael2021
Have you confirmed that this is the correct path?
If you run "ls /mnt/c/intelFPGA_pro/19.2/nios2eds/sdk2/bin" do you see the "nios2-bsp-update-settings" file?
- Michael20211 year ago
Yes, there is the "nios2-bsp-update-setting.exe" file
Even if I run it from where the file is, the same message appears
- AdrianaI_Altera1 year ago
Can you please confirm what OS are you using? Are you running this in a WSL command line?
Hi @Michael2021 could you please also confirm if you'd already tried to execute the nios2_command_shell.bat/.sh file from a Windows CMD or PowerShell (C:\intelFPGA_pro\19.2\nios2eds) to setup an environment for using the Nios2eds Software Build Tools?
