16 years agotelnetd or sshd on uclinux nommu de2?
Hello again,
is it possible to use either sshd oder telnetd on altera de2 cyclone2 mit uclinux? I added telnetd and inetd in the busybox options but nothing seems to happen. When i try to start telnetd manually it says: /> telnetd & [27] /> telnetd: getpeername: Socket operation on non-socket ���� ��#��' /> Is it a nommu thing or whats the problem?2 Replies
I'm using Linux so it may be different, though I think I was using a similar configuration with uClinux. I am using telnetd and inetd under "Network Applications" (not busybox) and they work fine. You don't need to start telnetd manually -- inetd will start it automatically when you telnet in.
I tried the busybox telnetd at some point and had some problems, don't remember what they were. - Altera_Forum
Some time ago I got ssh and the sshd running on the no-mmu system. Depending on what you're trying to do, telnetd is probably easier to get going. I thought there was a tutorial in the wiki about that. If you need help with ssh and you really want ssh, respond and I provide my notes. Alex
