16 years agotelnetd or sshd on uclinux nommu de2?
Hello again, is it possible to use either sshd oder telnetd on altera de2 cyclone2 mit uclinux? I added telnetd and inetd in the busybox options but nothing seems to happen. When i tr...
16 years agoI'm using Linux so it may be different, though I think I was using a similar configuration with uClinux. I am using telnetd and inetd under "Network Applications" (not busybox) and they work fine. You don't need to start telnetd manually -- inetd will start it automatically when you telnet in.
I tried the busybox telnetd at some point and had some problems, don't remember what they were.
