19 years agotcp_keepalive, again
How can I configure tcp_keepalive parameters on uClinux ? There's no "sys" directory in /proc. Can I create a "/proc/sys/net/ipv4/tcp_keepalivetime" file from Nios2ide ? Thanks for help Cédric1 Reply
The proc is a pseudo filesystem. You cannot create it in advance.
You can read linux-2.6.x/Documents/filesystems/proc.txt. Due the missing redirect in sash, you can look at the blackfin's uclinux, uClinux-dist/user/blkfin-test/audio_test/echo2.c And you should really work on Linux instead of nios2ide. <div class='quotetop'>QUOTE </div> --- Quote Start --- If you want to develop Nios II uClinux, you should work on Linux and learn Linux. You can learn a lot when working on Linux, and the "Linux know how" is the key to success on Nios II uClinux.[/b] --- Quote End ---
