Target is broken and needs to be reset
Quartus --> File --> Convert Programming Files --> Configuration Device-->EPCQ128A/EPCS16 and etc. I could not found a model that is the same as my flash model.
The flash that connect FPGA is M25P64(https://www.datasheetq.com/en/preview/M25P64-ST-Microelectronics)
I can't convert sof file to jic or pof file. so I have to try to flas
In Eclipse,
Quartus Tools --> NIOS II Software Build Tools for Eclipse --> NIOS II --> Flash Programmer, I encountered the following error.
In the following picture, some button and text is not appeared in NIOS II Flash Programmer. My OS is windows 10 professional English version, and the Eclipse is installed within Quartus 18.1 together
- DivyaG_Altera
Hi
As suspected in the thread : https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/flash-programmer-issue/m-p/1688748#M53698 the flash M25P64 may not be officially supported.
You may be able to workaround by finding a supported flash that matches it's configuration parameters such as opcodes & dummy clock cycles and use it's preset in the tools. However this may not be guaranteed to work as it's not verified by Altera.
Let me know if you had any questions.
Divya
- tehjingy_Altera
Hi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
