ZhiqiangLiang
1 year agoTarget is broken and needs to be reset
Hi, Quartus --> File --> Convert Programming Files --> Configuration Device-->EPCQ128A/EPCS16 and etc. I could not found a model that is the same as my flash model. The flash that connect FPGA is ...
DivyaG_Altera
1 year agoHi
As suspected in the thread : https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/flash-programmer-issue/m-p/1688748#M53698 the flash M25P64 may not be officially supported.
You may be able to workaround by finding a supported flash that matches it's configuration parameters such as opcodes & dummy clock cycles and use it's preset in the tools. However this may not be guaranteed to work as it's not verified by Altera.
Let me know if you had any questions.
Divya
