15 years agoSYSTEM_INFO to vhdl parameter
I would like to automatically pass the clock frequency to the generated component. For this I added a line in the _hw.tcl file to use the SYSTEM_INFO property. Unfortunately, the component is always generated with the default value of the parameter, not with the value of the clock it is connected to (ie. 50MHz). FILE _hw.tcl ... add_parameter SYSFREQ NATURAL 1 set_parameter_property SYSFREQ DEFAULT_VALUE 1 set_parameter_property SYSFREQ DISPLAY_NAME SYSFREQ set_parameter_property SYSFREQ UNITS None set_parameter_property SYSFREQ DISPLAY_HINT "" set_parameter_property SYSFREQ AFFECTS_GENERATION false set_parameter_property SYSFREQ HDL_PARAMETER true set_parameter_property sysfreq system_info {clock_rate clk} ... FILE .vhd ... entity my_component is generic ( sysfreq : natural := 1 ); port ( -- global signals signal clk : in std_logic; signal reset : in std_logic; ... FILE generated component ... my_component_0 : component my_component generic map ( sysfreq => 1 ) ... Is my approach correct ? If not, how should the value be passed to the component ? Thanks for your help, P91 Reply
found my mistake : the argument to SYSTEM_INFO CLOCK_RATE must be the interface name (mostly clock_reset), not the clock signal's name.
FILE _hw.tcl ... add_parameter SYSFREQ NATURAL 1 set_parameter_property SYSFREQ SYSTEM_INFO {CLOCK_RATE clock_reset} set_parameter_property SYSFREQ AFFECTS_GENERATION false set_parameter_property SYSFREQ HDL_PARAMETER true set_parameter_property SYSFREQ VISIBLE false ...
