15 years agoSYSTEM_INFO to vhdl parameter
Hi, I would like to automatically pass the clock frequency to the generated component. For this I added a line in the _hw.tcl file to use the SYSTEM_INFO property. Unfortunately, the com...
15 years agofound my mistake : the argument to SYSTEM_INFO CLOCK_RATE must be the interface name (mostly clock_reset), not the clock signal's name.
FILE _hw.tcl ... add_parameter SYSFREQ NATURAL 1 set_parameter_property SYSFREQ SYSTEM_INFO {CLOCK_RATE clock_reset} set_parameter_property SYSFREQ AFFECTS_GENERATION false set_parameter_property SYSFREQ HDL_PARAMETER true set_parameter_property SYSFREQ VISIBLE false ...
