16 years agosystem ID and system timestamp not found
Hi, I am facing problem in downloading Nios2 project into the hardware. The program indicate that system ID and system timestamp are not found on target at base address. The system ID properties show...
13 years agoDear All,
I am facing the same issue. But i have checked all of the trouble shooting points... Kindly let know where i could be going wrong... I am using Cyc III with NIOS II and Quartus II 12.0 sp1. I have been using it to program and flash using Flash Programmer in NIOS IDE. Recently i wanted to test some stubs so copied the project to another folder using Project > Copy Project option. Then after removing all logic and retained only required ones... And doing a JTAG for Quartus and NIOS too... (NIOS - RUN CONFIGURATIONS AS NIOS HARDWARE) have included sysid and timer in QSYS model. I follow the steps correctly... 1. Generate QSYS, 2. Compile Quartus II, 3. Generate BSP in NIOS, 4. Copy SOPC file (.sof) using JTAG, 5. then run - "RUN CONFIGURATION" from NIOS IDE. I keep getting Mismatch in sysid and timestamp. Kindly help.
