16 years agosystem ID and system timestamp not found
Hi, I am facing problem in downloading Nios2 project into the hardware. The program indicate that system ID and system timestamp are not found on target at base address. The system ID properties show...
15 years agoGenerally, sysid ip core should be added in your SOPC system, and rename it sysid.sysid and timestamp are updated at every generation in SOPC Builder,then BSP in Nois SBT should be regenerated.
Before download software file(debug or run in Nois SBT),.sof file must be download to your FPGA.Because when you debug or run program,Nois SBT read sysid and timestamp from the hardware in FPGA.
