16 years agosystem ID and system timestamp not found
Hi, I am facing problem in downloading Nios2 project into the hardware. The program indicate that system ID and system timestamp are not found on target at base address. The system ID properties show...
16 years agoHi, is the Nios II working fine before adding those components?
Some of the steps i usually do after modify SOPC Builder are making sure that i load 'xxx_time_limited.sof' instead of 'xxx.pof'; right click 'xxx_bsp'(in Nios II project workspace)->Nios II->BSP Editor->Linker Script and restore default to the both Region Name and Section Name; and click 'Generate BSP' in the same menu as 'BSP Editor'.
