16 years agosystem ID and system timestamp not found
Hi, I am facing problem in downloading Nios2 project into the hardware. The program indicate that system ID and system timestamp are not found on target at base address. The system ID properties show...
16 years agoI have tried create a new run config but it does not work. I might have overlook some procedure while loading Nio2 2 into DE1...can someone with experience of using Nios 2 and DE1 provide me with important steps to download nios 2 into DE1?
Btw...is it correct to set the switch to RUN instead of PROG when loading Nios 2? And do I need to connect AC supply while programming Nios 2? I'm currently using voltage supply from USB. I'm also getting "Warning: Found invalid timing assignments -- see Ignored Timing Assignments report for details" In the Ignored Timing Assignments: Cut Timing Path On * data_in_d1 nios_reset_clk_0_domain_synch_module No timing path applicable to specified source and destination Cut Timing Path On * data_in_d1 nios_reset_clk_0_domain_synch_module Is this timing assignment issue the cause of my problem?
