20 years ago
step-14: Buildroot Guide
Hi Hippo,
After running uclinux successfully on startix pro (Nios II).
I have to enable some applications:
1. telnel
2. tftp
3. SSH login
According to step 14, i will able to enable those apps.
After selecting those options through menuconfig.
It got failed at "make subdirs".
Kindly, Explain step 14 little-bit more. so i can configure any apps.
thanks & regard,
Goutam
    --- Quote Start ---
    originally posted by goutam_kumar@May 9 2006, 07:13 PM
    hi hippo,
    after running uclinux successfully on startix pro (nios ii).
    i have to enable some applications:
    1. telnel
    2. tftp
    3. ssh login
    according to step 14, i will able to enable those apps.
    after selecting those options through menuconfig.
    it got failed at "make subdirs".
    kindly, explain step 14 little-bit more. so i can configure any apps.
    thanks & regard,
    goutam
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15218)
    --- quote end ---
    --- Quote End ---
    Please enable only one apps at a time, to see which failed to make.
    Check the compile message. Lack of include file ?
    You can also try the same patches against stable release of uClinux-dist, which may have better result. I will change the buildroot guide and build script to use the stable one instead of test release.
    Hi Hippo,
    Thanks for hint.
    I was doing same what you have instructed.
    while doing "make romfs". it is going failed.
    The required ".config" file for ~/rootfs/etc for an apps is not so clear.
    Acknowledge me, when you will modify the buildroot guide steps.
    I compiled for busybox using step 14. it got hang with vfork in
    "~/uClinux-dist-test/user/busybox/networking/inetd.c: line766"
    with following error
    /home/goutam/uClinux-dist-test/user/busybox/networking/inetd.c:766: error: too few arguments to function `vfork_daemon_rexec&#39;
    make[2]: *** [/home/goutam/uClinux-dist-test/user/busybox/networking/inetd.o] Error 1
    make[2]: Leaving directory `/home/goutam/uClinux-dist-test/user/busybox&#39;
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/home/goutam/uClinux-dist-test/user&#39;
    make: *** [subdirs] Error 1
    thanks & regard,
    Goutam
