20 years agostep-14: Buildroot Guide
Hi Hippo, After running uclinux successfully on startix pro (Nios II). I have to enable some applications: 1. telnel 2. tftp 3. SSH login According...
20 years ago --- Quote Start --- originally posted by goutam_kumar@May 9 2006, 07:13 PM hi hippo,
after running uclinux successfully on startix pro (nios ii).
i have to enable some applications:
1. telnel
2. tftp
3. ssh login
according to step 14, i will able to enable those apps.
after selecting those options through menuconfig.
it got failed at "make subdirs".
kindly, explain step 14 little-bit more. so i can configure any apps.
thanks & regard,
goutam
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15218)
--- quote end ---
--- Quote End --- Please enable only one apps at a time, to see which failed to make. Check the compile message. Lack of include file ? You can also try the same patches against stable release of uClinux-dist, which may have better result. I will change the buildroot guide and build script to use the stable one instead of test release.
