20 years ago
stand alone lwIP -help
I have developed a PCB with 2 ethernet ports. Both ports are a copy of the hardware from the development PCB. I was able to get the stand alone lwIP web server running on the dev. PCB but it won't run on my PCB. I did change the name of my ethernet modules to lan91c111_0 & lan91c111_1 in SOPC builder. Where can I make to change in the lwIP code to call out my new module names.
    Does LWIP even support two ports? I know Linux and eCos do...
    I figured out the answer to my problem. For anyone who may face the problem
    The line in code
    dev_list_ptr = (alt_avalon_lan91c111_if*)alt_ethernet_device_list.next;
    can also be changed to
    dev_list_ptr = (alt_avalon_lan91c111_if*)alt_ethernet_device_list.previous;
    You can use these functions to alternate between the different ports on the PCB.
    Thanks for taking the time to respond Mike.
