20 years agostand alone lwIP -help
I have developed a PCB with 2 ethernet ports. Both ports are a copy of the hardware from the development PCB. I was able to get the stand alone lwIP web server running on the dev. PCB but it won'...
20 years agoI figured out the answer to my problem. For anyone who may face the problem
The line in code dev_list_ptr = (alt_avalon_lan91c111_if*)alt_ethernet_device_list.next; can also be changed to dev_list_ptr = (alt_avalon_lan91c111_if*)alt_ethernet_device_list.previous; You can use these functions to alternate between the different ports on the PCB. Thanks for taking the time to respond Mike.
