SSRAM Verify failed after adding custom components in SOPC Builder
I created a system based on the template for the Stratix II Nios Kit. I took the SDRAM away since I don't have a license for that IP Core. I intended to use SSRAM since it's a small project. I compiled in quartus and programmed the FPGA then created a hello world application in Nios IDE and it compiled and run ok. Now when I add custom components in SOPC Builder like PWM and ADC interface, generate, assign pins, compile in quartus, and try to compile in Nios IDE I get verify failed at address 0x01000000.
I configured unused pins as tristate inputs and triple check pins assignments so I don't know what could be the problem. Can anyone help me please?15 Replies
anyone please?
Did you constrain the memory interface and does your design meet the timing requirements when you compile it?
hi i have the same problem i'm using an ssram in my design at STRatix II and the rpject compiled successufilly but when i use the NIOS IDE with the project of hello world the project build with no error but when i run it i have this problem
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x00801040: verified Initializing CPU cache (if present) OK Downloading 00400000 ( 0%) Downloaded 53KB in 0.9s (58.8KB/s) Verifying 00400000 ( 0%) Verify failed between address 0x400000 and 0x40D073 Leaving target processor paused plz some one can help me - Altera_Forum
what do u mean by memory interface and yes when i compile i have timing requirements
By memory interface I mean the FPGA pins that are connected to the memory. You should check that your timing contraints file is correct on those signals.
i chek right now rtl viewer this i the schematic
where can i find it i'm new n this
You need to familiarize yourself with Timequest. There is a good user guide on the wiki (http://www.alterawiki.com/wiki/timequest_user_guide).
thks but i'm limited with time
