15 years agoSSRAM Verify failed after adding custom components in SOPC Builder
I created a system based on the template for the Stratix II Nios Kit. I took the SDRAM away since I don't have a license for that IP Core. I intended to use SSRAM since it's a small project. I compil...
14 years agohi i have the same problem i'm using an ssram in my design at STRatix II and the rpject compiled successufilly but when i use the NIOS IDE with the project of hello world the project build with no error but when i run it i have this problem
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x00801040: verified Initializing CPU cache (if present) OK Downloading 00400000 ( 0%) Downloaded 53KB in 0.9s (58.8KB/s) Verifying 00400000 ( 0%) Verify failed between address 0x400000 and 0x40D073 Leaving target processor paused plz some one can help me
