15 years agoSSRAM Verify failed after adding custom components in SOPC Builder
I created a system based on the template for the Stratix II Nios Kit. I took the SDRAM away since I don't have a license for that IP Core. I intended to use SSRAM since it's a small project. I compil...
15 years agoDid you constrain the memory interface and does your design meet the timing requirements when you compile it?
