15 years agoSSRAM Verify failed after adding custom components in SOPC Builder
I created a system based on the template for the Stratix II Nios Kit. I took the SDRAM away since I don't have a license for that IP Core. I intended to use SSRAM since it's a small project. I compil...
14 years agoBy memory interface I mean the FPGA pins that are connected to the memory. You should check that your timing contraints file is correct on those signals.
