21 years ago
SPI Slave bug?
Has anybody used the SPI core as a slave device in a NIOS II implementation? If so, have you had relatively frequent data errors?
There is no HAL for the SPI as slave, so I'm just using the IORD... and IOWR... macros defined in altera_avalon_spi_regs.h. I've tried both polling and ISR implementations, yet I keep getting data errors. I originally suspected noise on the SCLK or MOSI lines, but they look golden -- no glitches.
Example: the SPI master sends 3 bytes -- 0xF1, 0x41, 0xF6. Most times, that's what I get, but over 10% of the time (!) I see examples such as: 0xF1 0x20 0xF6, or 0xF1 0xA8 0x81 0xF6 (and there are only 3 bytes sent, looking at the SCLK and MOSI lines), or 0xF1 0x41 0xBD.
Here's my interrupt handler (the protocol stuff isn't relevant):
void SpiSlave::InterruptHandler(void)
U_INT32 irq_flag_reg;
U_INT32 irq_mask_reg;
U_BYTE RxChar;
static U_BYTE GotHeader = FALSE;
IsrCount++;
// read register to determine which flags are set
irq_flag_reg = IORD_ALTERA_AVALON_SPI_STATUS(BaseAddress);
// read the interrupt mask register
irq_mask_reg = IORD_ALTERA_AVALON_SPI_CONTROL(BaseAddress);
while (irq_flag_reg &= irq_mask_reg) {
// Check for Rxed character
if (irq_flag_reg & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) {
RxIsrCount++;
if (RxMsgSize >= SPI_SLAVE_RX_BUFFER_SIZE) { // buffer overflow
// queue an event
RxMsgSize = 0;
GotHeader = FALSE;
RxChar = IORD_ALTERA_AVALON_SPI_RXDATA(BaseAddress);
if (GotHeader) {
RxDataBuffer[RxMsgSize++] = RxChar; // store char in temp buffer
if (RxChar == (U_BYTE)0xF6) { // ETX char received
GotHeader = 0;
DisableInterrupt(ALTERA_AVALON_SPI_CONTROL_ITRDY_MSK); // no more TRDY
if (NewMsgRxed) { // app hasn't processed the last msg yet!
// queue event
else { // ready to give msg to application
// copy data to app buffer
while (RxMsgSize--) {
AppRxBuffer[RxMsgSize] = RxDataBuffer[RxMsgSize];
NewMsgRxed = TRUE;
RxMsgSize = 0;
} // end if ETX
else { // not ETX
if (RxChar > (U_BYTE)0xF0) { // unexpected header
// start msg all over, beginning with the new header
// note that GotHeader is already TRUE
RxMsgSize = 0;
} // end if unexpected header
} // end if not ETX
} // end if GotHeader
else if ((RxChar > (U_BYTE)0xF0) && (RxChar != (U_BYTE)0xF6)) { // Header rxed
GotHeader = TRUE;
RxMsgSize = 0;
} // end if Rx Rdy interrupt
if (irq_flag_reg & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) {
TxIsrCount++;
if ((BytesToSend) && (TxData)) { // data to tx
IOWR_ALTERA_AVALON_SPI_TXDATA(BaseAddress, *TxData++);
BytesToSend--;
else {
// nothing more to send, so disable ints to avoid infinite ints
if (irq_flag_reg & ALTERA_AVALON_SPI_STATUS_ROE_MSK) {
// Rx overrun error -- queue event?
if (irq_flag_reg & ALTERA_AVALON_SPI_STATUS_TOE_MSK) {
// Tx overrun error -- queue event?
// re-read register to determine which flags are set
// Clear status bits by writing anything to the status register
//IOWR_ALTERA_AVALON_SPI_STATUS(BaseAddress, 0);
} // end while
} // end SpiSlave::InterruptHandler()
