21 years agoSPI Slave bug?
Has anybody used the SPI core as a slave device in a NIOS II implementation? If so, have you had relatively frequent data errors? There is no HAL for the SPI as slave, so I'm just using th...
16 years agoAny news here?
I'm experiencing similar problems. My Cyclone III is configured as Slave another controller as Master. For testing I set up the master to send 0x5555 and the slave to send 0xffff all the time. As I did not receive the right values in both direction I took a look at the bus. You may want to have a look at the screenshots: yellow - clock green - slave select blue - MOSI red - MISO The data the code of the master shows are exactly the same I can see on an oscilloscope. So there cant be a problem on masters side. The data I want to send from slave's side varies on the bus (as shown on the screenshots). And the data I receive on slave's side seems to be totally random. I've never received valid data in slave. I've not tried yet to interchange master-slave to see if this is caused by a faulty slave driver. I anyway prefer it to have it the way it is and to solve the problems. Any hints are appreciated. Kind Regards.
