21 years agoSPI Slave bug?
Has anybody used the SPI core as a slave device in a NIOS II implementation? If so, have you had relatively frequent data errors? There is no HAL for the SPI as slave, so I'm just using th...
21 years agoEmail me if you are not up and running and I can give you some code I made for a slave device (it's not interupt based but it may point out what's failing in your design).
