21 years agoSPI Slave bug?
Has anybody used the SPI core as a slave device in a NIOS II implementation? If so, have you had relatively frequent data errors? There is no HAL for the SPI as slave, so I'm just using th...
21 years agoI'm using Quartus II v5.0 Build 168, NIOS II v5.0 Build 73c. The clock speed is 65 MHz, and the SCLK is currently about 1MHz, though we've tried a range from about 44 KHz to about 2 MHz, with no difference in results.
I've found that if I have never loaded the TX register, the master reads back 0xFF, and that if I have loaded it with some byte, that same byte will be read out until I re-load the TX register. Thanks for the interest. You've gotten the SPI slave to work reliably? I haven't seen anything on this or the Altera forums about anybody using the SPI core as a slave. Everybody's always talking about it as a master. I have no problems at all with my SPI master, which makes this seem kinda weird.
