20 years ago
SOPC Builder
ciao to everybody
I'm trying to build a new system with cpu nios 2 , sdram ,tristate bridge
and my user component
I import my component vhdl file and i declare 2 port that in slave are input
but in sopc i declare "writedata" .
I flag on for generate header files ect
At the end i click on "Generate" and sopc gerates for me my new system
After i go to check in cpu_sdk the three folders
-inc
-lib
-src
Here i can find many .h and .c files , about PIO , LCD , UART
but i didn't found no one file i'm interesting
How can i do?
How can i interface my application C/C++ in Nios II IDE with my
user component ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
thanks for helps
walter
ciao
    now i&#39;m trying your example
    i create a new quartus 2 project, import your vhdl file and set it
    as top-level , start compilation and finish good .
    I open SOPC builder and import this component , and declare
    the port slave like you wrote .
    Add it in my system , and ready to generate .
    One question :
    in the SOPC builder , Avalon bus slave reserve for the component 16 word registers
    base address =0x00000800
    end=0x0000080F
    I use only register 0 ,1,2 ,3 , but what does they means other 11 registers?
    http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
    ciao
    walter
    address width is 2
    writedata width is 32 (4 Byte)
    addressrange is (2^2)*4 = 16 addresses
    in your case controlregister is at base address=0x00000800
    reg1 (base divider) is at address=0x00000804
    but you don&#39;t have to take this in account, if you use the MACROS
    IOWR and IORD.
    e.g.
    IOWR(AV_CLOCK_0_BASE,CPU_CLK_DIVIDER,50000);
    calculates the absolute address AV_CLOCK_0_BASE+4*CPU_CLK_DIVIDER
    (in your case 0x00000800)+(4*1)=0x00000804
    avalon interface is little endian
    "Little Endian" means that the low-order byte of the number is stored in
    memory at the lowest address, and the high-order byte at the highest address.
    (The little end comes first.)
    writing 32 bit (e.g. 0x12345678) into controlregister writes:
    *(0x00000800)=0x78 Byte0
    *(0x00000801)=0x56 Byte1
    *(0x00000802)=0x34 Byte2
    *(0x00000803)=0x12 Byte3
    hope this helps
