19 years ago
Socket Program.
Hi,everybody
I have build a socket program,it has server and client program.
I will run server on De2 board and client on PC.
But I have problem.
Client is excute on "colinux" or "NiosII SDK shell"?
How to compile client program and run on PC?
I don't know "compile" and "excute" command on colinux?
Need your help!
NiosQ
    You can use gcc to compile your client program, and run it within coLinux shell. But coLinuxs needs a virtual network adaptor driver to access network interface (or bridge) from Windows. You may read the wiki of coLinux or Blackfin.
    I would suggest you install a native Linux on one partition of your PC, eg CentOS 4.4. It would be easier than coLinux for a newbie.
    --- Quote Start ---
    originally posted by hippo@Mar 21 2007, 10:14 AM
    you can use gcc to compile your client program, and run it within colinux shell. but colinuxs needs a virtual network adaptor driver to access network interface (or bridge) from windows. you may read the wiki of colinux or blackfin.
    i would suggest you install a native linux on one partition of your pc, eg centos 4.4. it would be easier than colinux for a newbie.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=22395)
    --- quote end ---
    --- Quote End ---
    Hi,hippo
    Your are Nios God!
    great!
    thank for your response.
    I&#39;m a Nios newbie. If i use centOS ,then how to setup network?
    I use centOS just compile client program and run it.
    Can you teach me how to compile client program and run it on CentOS?
    thank your very much!
    NiosQ
