19 years agoSocket Program.
Hi,everybody I have build a socket program,it has server and client program. I will run server on De2 board and client on PC. But I have problem. Client is excute on "colinux" or "NiosII ...
19 years ago --- Quote Start --- originally posted by hippo@Mar 21 2007, 10:14 AM you can use gcc to compile your client program, and run it within colinux shell. but colinuxs needs a virtual network adaptor driver to access network interface (or bridge) from windows. you may read the wiki of colinux or blackfin.
i would suggest you install a native linux on one partition of your pc, eg centos 4.4. it would be easier than colinux for a newbie.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22395)
--- quote end ---
--- Quote End --- Hi,hippo Your are Nios God! great! thank for your response. I'm a Nios newbie. If i use centOS ,then how to setup network? I use centOS just compile client program and run it. Can you teach me how to compile client program and run it on CentOS? thank your very much! NiosQ
