22 years ago
Small steps
Ok so I got linux to compile and run.
The next step is to do a simple hello world which was fine done.
now I want to write a app that can use the LCD or led
I had a look at lcd_demo1.c under the pio_lcd16207 section of the NIOS II decives.
I tried to create a new app with this as the c file and had a lot of errors.
Does anyone have any Ideas?
thanks
peter
1 Reply
    The lcd_demo1.c is not an application for Linux, therefore, you cannot use it directly on Linux. My suggestion is to implement a Linux driver for LCD.
    For LED, there are some support in kernel, although they are simple. If you want to implement a driver that can be interfaced by your application, you can refer to the pio button driver in the kernel.
