22 years agoSmall steps
Ok so I got linux to compile and run. The next step is to do a simple hello world which was fine done. now I want to write a app that can use the LCD or led I had a look at lcd_demo...
22 years agoHi,
The lcd_demo1.c is not an application for Linux, therefore, you cannot use it directly on Linux. My suggestion is to implement a Linux driver for LCD. For LED, there are some support in kernel, although they are simple. If you want to implement a driver that can be interfaced by your application, you can refer to the pio button driver in the kernel.
