16 years agoSlow DDR access.
Hi Guys, We are using Nios II with a DDR HP Controller in full-rate, both at 100MHz on Cyclone III. The design is an SOPC builder with Avalon-MM interface. Our DDR Memory is a single device 16b...
16 years agoDon't panic! :-)
In component editor you should declare external_sys_clk as "conduit_end"-Interface with "export"-Signal Type. In .tcl file you then see somethink like that: add_interface_port conduit_end external_sys_clk export Output 1 That's all! Regards, Kest
