aiedb's avatar
aiedb
3 years ago
simple socket sever-max 10 neek
hii
i have the max 10 neek dev board
and i would like to run the socket-server in the demonstration folder -
the dev board comes with a cd which has all types of examples
i followed the link below :
https://www.youtube.com/watch?v=CAY2NSB0XEw
the project is as i said from the :
MAX10_NEEK_v.1.0.7_SystemCD
so it suppose to work , but some how when i open nios 2 , i can see that there are 2 error ,and when i go to the problem tab to see what is the error , i don't see what the error is :
i attached the file from the nios , i be glad for any help .
  • ShengN_altera's avatar
    ShengN_altera
    Hi @aiedb ,
    Any further update? Does the more updated example design working well?
    Sheng
    • aiedb's avatar
      aiedb
      hii ,good morning
      i downloaded the example , and i restored the archived project
      and i don't see that there are output folder which have sof file of the project .
      so i opened the system in qsys in order to compile the project , to produce sof file , but somehow the qsys gets stuck while opening the system , and i am not able to compile the project .
      i tried restarting my my pc and restarting quartus without any success unfortunately.
      i think my best chance if you have a project that works , even the demonstration project of max10 neek , if you can zip it and upload it to gethub or onedrive and send me a link so i can download it into my pc ,and try it out
      thanks for your kind help
    ShengN_altera
    Hi @aiedb ,
    The sof file is in the master_image folder. I attahced the .sof file and .sopcinfo files below. The rest you just follow the steps in this document https://www.intel.com/content/dam/support/us/en/programmable/support-resources/fpga-wiki/asset03/simple-socket-ethernet.pdf will do. Make sure eclipse KEPLER is used to create the bsp software files.
    Sheng
    • aiedb's avatar
      aiedb
      hii good morning , unfortunately i give every thing that i had , and i didn't manage with it .
      if you have a working version, could you please zip the entire project folder ,as it is not a qar file ?
      and send me a link to zip file , so i can unzip and try it out on the max10 neek eval board that i have
    ShengN_altera
    Hi @aiedb ,
    I had tested the MAX10_NEEK_v.1.0.7_SystemCD socket server design on MAX 10 NEEK board (image):
    and worked as expected (image):
    File attached below. One more concern will be are you using Altera USB-Blaster II for programming?
    Make sure also Ethernet cable is connected.
    Also when Auto Detect, make sure you're choosing 10M50DAES.
    As for Design Store socket server design, you have to use this MAX 10 board (image):
    Sheng
    • aiedb's avatar
      aiedb
      hii
      thanks so much for your help
      today i managed to activate the socket server completely finally , i was wondering i want to do a project that the max10_neek div board will be a udp_client that sends a message periodically to a pc (the pc will be a udp server ) , the pc will receive the message and send a reply to the udp client (max10 neek)
      is there any example design that's gets me started ?
    ShengN_altera
    Hi @aiedb ,
    As this is effectively a new question and seems unrelated to the problems we have been addressing in this current CASE, I would prefer a new thread to address it in for better viewing.
    I will close this current case and will pick up the new one when it comes in.
    Sheng
    • aiedb's avatar
      aiedb
      hii
      good morning
      , thanks for your help i will open up a new case , thanks
