simple socket sever-max 10 neek
Hi @aiedb ,
I had tested the MAX10_NEEK_v.1.0.7_SystemCD socket server design on MAX 10 NEEK board (image):
and worked as expected (image):
File attached below. One more concern will be are you using Altera USB-Blaster II for programming?
Make sure also Ethernet cable is connected.
Also when Auto Detect, make sure you're choosing 10M50DAES.
As for Design Store socket server design, you have to use this MAX 10 board (image):
Sheng
- aiedb3 years ago
hii
thanks so much for your help
today i managed to activate the socket server completely finally , i was wondering i want to do a project that the max10_neek div board will be a udp_client that sends a message periodically to a pc (the pc will be a udp server ) , the pc will receive the message and send a reply to the udp client (max10 neek)
is there any example design that's gets me started ?
