set_output_delay explained for dummies
Hello. I have tried to wrap my brain around the documentation describing "set_output_delay", but I just don't seem to get it.
My brain thinks like this: "Relative to the rising-edge of my output clock, the output data needs to be valid after 1 ns and remain valid for 2 ns". The documentation describes this: "The maximum output delay (-max) is used for clock setup checks or recovery checks and the minimum output delay (-min) is used for clock hold checks or removal checks. " So to me (please correct me if I'm wrong), "setup" sounds like the earliest time the data needs to be valid, and "hold" sounds like where the data is no longer required to be valid....But datasheets usually define setup as the time to the left of the clock, and hold as the time to the right of the clock. Since the valid window is to the right, one of these values should be negative? set_output_delay -max -1 set_output_delay -min 3 am I even close?18 Replies
Yes, I'm just saying it's unlikely you'll make timing. The delay chains only make it longer. They can't make the delay negative. You can shift your launch clock back with a PLL and use multicycles to say the data is launched before 0ns, but I don't think that really makes sense.
Isn't pushing the output clock forward time equivalent to pushing the data backwards in time? Why wouldn't that make sense?
I thought I had it, but I think I'm back to being confused. I guess I'm still confused as to why anything needs to be pushed negative in time. If the clock is output a time zero, and the data needs to arrive at t=1.0ns, wouldn't the proper skewing be that I need to add positive delay to the data and no delay to the clock? - Altera_Forum
The ideal clock occurs at both the FPGA and the external device at times 0ns, 10ns, etc. If the FPGA needs to get its data out within 1ns, then making the clock delay to the external device longer would help with this setup, but the clock delay to the external device is outside the FPGA, i.e. the FPGA fit can't affect that. The only things the FPGA can affect are the clock coming into the FPGA to the output register(launch clock path) and the delay from the register to the output port(data path). These two things make up the Data Arrival Path, and we essentially want them to be less than 1ns.
I recommend not spending a lot of time on hypotheticals and instead figure out your specific timing case. There are all sorts of ways you can confuse yourself with hypotheticals that are not worth the time. - Altera_Forum
Ah okay. Your post has made me realize that I was thinking the data would arrive too early (and maybe/maybe-not going invalid before 3.0 ns) while I think you were implying it would probably arrive too late to meet the 1.0 ns requirement.
In super general concepts: The FPGA data output is going to have its own output-valid window relative to that register's clock. I need to do whatever it takes to make sure the output valid window overlaps the downstream's devices input valid window (delay either clock or data, as appropriate). I should account for PCB delays and length-mismatches as well. - RichardT_altera
windy_city As I mentioned in another forum thread that you responded, you can find the document here:
https://www.scribd.com/document/247234977/TimeQuest-User-Guide
Richard Tan
