21 years agoService Pack 1, Nios II 1.0
Service Pack 1 for the Nios II v1.0 release is now available for free download: nios ii 1.0 sp1 (https://www.altera.com/support/software/download/service_packs/nios/dnl-nios2_1_0_sp1.jsp). This service pack will update your Nios II tools' version number to "1.01".
To determine if you need this service pack, please check out the online nios ii 1.01 release notes (http://www.altera.com/support/ip/processors/nios2/ips-niosii-dev-kit-101-rn.html).13 Replies
--- Quote Start --- originally posted by neo@Dec 18 2004, 11:00 PM do you know where can i get nios ii 1.0? --- Quote End --- Hello neo, You can download the Evaluation Version from Altera or you can buy the Nios II license from an Altera distributor. Bye, niosIIuser - Altera_Forum
Be careful here.
I pruchased a Cyclone eval board and got Quartus II 3.? and NIOS I Then in august I got an update Q II 4.0 and NIOS II 1.0 but an evaluation only version I then downloaded the NIOS II 1.0 full version from the web. I ended up with NIOS II 1.0 but NO MicroC RTOS support. And perhaps I'm missing other stuf I evevtually got a CD from the factory. NIOS II Ver 1.0 and it had the MicroC RTOS. - Altera_Forum
--- Quote Start --- originally posted by niosiiuser@Nov 5 2004, 02:43 AM hello jdkirby,it?s the same behaviour with the stand-alone lwip from microtronix. the sp 1 for nios ii should be installed after adding uclinux (or stand-alone lwip) to your system.
1. uninstall your nios ii 1.0.1
2. install nios ii 1.0
3. install uclinux
4. install sp 1 for nios 1.0
bye,
niosiiuser --- Quote End --- That makes sense. Upgrades and patches were available when I first installed on this computer and I didn't bother to RTFM. Foolish mortal! This is the error you get installing Nios II SP1 if you do it Leslie's way: The directory: c:\altera\kits\nios2 Does not contain the expected Nios II installation(found 1.01). Please select a directory with an installation of Nios II 1.0 to continue. I assume I will have to uninstall and reinstall Nios II and uClinux at some point.
